| Firing OrderApril 2 2008 at 12:43 PM | Derek (no login) |
Response to 327Q Camshaft Question |
| Paul,
Good idea. I called them again, they said they are only aware of 1 firing order - the standard SBC firing order. They said that the particular grind I have is their standard marine grind which has a bit more lift. Otherwise the camshaft is OEM.
I know I have seen reference to ChrisCraft's "non-standard" firing order on here before but I think it comes down to how you number the cylinders, not in any change in the sequence. ChrisCraft uses standard numbering methods but they turn the engine around. Last night I went through the exercise of translating flywheel forward numbering to automotive flywheel aft - and the sequence was identical. Is that correct?
Thanks,
Derek |
