|  Fuel pumpJanuary 30 2008 at 12:50 PM | Eric Jensen  (no login) |
  Response to Hard Starting 427 |
  |  I don't want to offend anyone by asking the obvious, but is there ANY chance that you have electric fuel pumps with oil pressure cut-off switches and that you are not cranking long enough to build pressure and turn on the switch. Each time you try to crank the engines you may be stopping just short of the point that the switches see pressure and turn "on" 10 pumps ought to be enough to get some life out of an engine with no choke at all.
Don't ask me how I found out about this.
Eric    |
  |  | Responses |
