| Choke adjustmentJanuary 29 2008 at 12:06 PM | Steve (no login) |
Response to Hard Starting 427 |
| I had the similar problem with my 427's. Once they're running do you see black soot out of one or both exhaust dumps? I found by adjusting the auto choke setting the motors lit right up when cold. Make sure the choke plate is in the closed position when the motors cold and that its wide open when at running temp. You can adjust the position by loosening the (3)screws on the plastic cover plate and rotating it until you get the choke plate in the desired position. Hope this helps, it did for me.
Steve
'69 42' Commander
Bear Z Girl |
