| Locked MotorOctober 30 2006 at 9:35 AM | Rob (no login) |
Response to Removed valve cover photo |
| Paul
If the motor is locked, try mixing some ATF with the PB Blaster. I had bought a Crestliner (as a bank repo) that had been laying for several years and the motor was locked solid, teh bank even had a mechanic work on it and he said the motor was shot. I pulled the plugs and filled the cylinders with CRC and ATF and let it set for 2-3 weeks and put a breaker bar on crankshaft and bumped the engine a little filled cylinders and let it set and bumped some more. Engine ran fine and did not smoke or use oil for 4 years I had it and I think it is still running 16 years later. The chemical mixture with ATF does something to dissolve rust and loosens the rings.
Rob
The Eagles Nest |
