Ground problem
July 20 2006 at 2:47 PM
  (Login Commander1)
Response to Instrument eletrical problem
Hi Bill, this probably won't be much help, but I had something similar happen on our Commander when I was trying to hook up the lights for the new electric tachometers I installed. When I hooked the ground up, the instruments went crazy. I checked between the instrument ground and engine block with a digital volt meter, and found about 6 volts. It should have been zero volts.
Sometimes ground systems get some circulating currents in them that can cause problems. I didn't take the time to trace down the problem because the old ground wire was in a place where I really couldn't reach it. I just dragged in a new ground wire from a spot where I knew I had a good ground, and that fixed the problem.
So, you might try fishing in a new ground that you know is good, and see if that fixes the problem.
Best wishes, Curt....
1967 fiberglass 38' Chris Craft Commander Sportfisher with twin 427 CID 300 HP engines.
