| Problems FixedJune 12 2006 at 8:57 PM | Bill (no login) |
Response to 427 Problems |
| Thanks to everyone's input, but this is what has transpired. Sure enough I didn't turn the valve back on to the fresh water pump so that quickly fixed my overheating problem.
Then got it out again and had a repeat cut out and die. This time I had my son push the throttle several times, and got fuel the first 4 pumps then it went dry. Then 20 seconds later it pumped a little more in so I new I had a fuel problem.
I pulled the filter which was completely plugged, and ended up removing the gas tank and getting it "dipped". Now I'm off to happy sailing so thanks for everyone's input. It's what ultimately got the correct diagnosis.
Bill |
