| Transmission tribulationsDecember 6 2008 at 3:21 PM | Craig Nash (no login) from IP address 207.216.14.224 |
Response to The work is done on the tranny |
| You might check into the cost of having your main case replaced with a good used wide pattern case by one of the toploader rebuilders, vs. the cost of getting the other swap over parts. |
