MEL BLOCK DIFFERANCES????
October 3 2008 at 4:38 PM
Anonymous  (Login bestrada11)
from IP address 75.146.142.118
is there any differances between the mel blocks from 58 throguh 67??
(Login hawkrod)
MEL Forum Moderator
207.200.116.6
Lots of changes ove the years and so blocks are not interchangeable
October 5 2008, 7:43 AM
from 5 threads down: http://www.network54.com/Forum/257364/thread/1221528322/Time+to+bring+this+one+back+to+the+top%2C+lots+of+pictures+back+of+blocks+and+bolt+patterns This is the biggest change but there are others. Early blocks have different mounts, cam retainers changed etc... Hawkrod
Hawkrod
39 Ford Deluxe Coupe
59 Tbird 430
60 Lincoln Premier
(2)62 Tbirds
(3)68 Cougar XR7-G's
69 Cougar 428CJ 4 speed
86 SVO mustang
76 F250 Crew Cab
1969 Mach I
BRIAN
(Login bestrada11)
71.228.126.143
Re: MEL BLOCK DIFFERANCES????
October 6 2008, 7:26 PM
Actually im more wondering what would prevent the universal fit of this LM671 manifold i have if it is new and unused.... what im thinking is if the ports are un polished you could theoreticly open them us and gasket match the ports to the heads if need be right??? by the way this is the weind 6-71 blower manifold....
(Login KULTULZ)
MEL Forum Moderator
69.140.42.35
Cylinder Head Differences
October 17 2008, 2:58 AM
Your intake will fit any series MEL head.
The early 58 was unique, and replaced by a head for 58/59 production. The 60/62 were 2V and slightly smaller ports. The 63/65 430 was a new style head for the 4V (requiring special pistons). The 66/68 462 head had slightly smaller runners.
I would try to port match with the gasket and head ports and not cut the intake as this thing will be gold with no modifications.
(Login bestrada11)
71.228.126.143
Re: Cylinder Head Differences
October 17 2008, 8:42 PM
so i guess i should sit on this thing then and leave it untouched... it is turning the dull black oxidized color would it hurt the value if i bead blasted it to shine it up a little??
(Login KULTULZ)
MEL Forum Moderator
69.140.42.35
Use It
October 18 2008, 6:31 AM
What I am saying is that if you port the intake to the heads, it may reduce its' resale value. Try to port the head runners to the intake.
I would think that a mild media surface cleanup would not hurt the resale value.
No reason not to use and enjoy. Photos welcome...
Current Topic - MEL BLOCK DIFFERANCES????
Neue Seite 5
