need 462 crank
September 3 2008 at 9:35 AM
  (Login 00llama)
from IP address 140.239.87.194
I need a 462 crank that will clean up at .010 or less. Last three have not made it. Need crank for stroker motor, offset grind, not rebuild. TJR
(Login 56vickyMEL)
75.89.136.48
Re: need 462 crank
September 4 2008, 5:04 PM
Can you elaborate? I want to the same thing. what happened to them? Maybe I'll just go the billet route.
(Login 00llama)
140.239.87.194
.020 cranks
September 5 2008, 9:34 AM
Have found three cranks, two out of running engines. All have had to be turned at least .020 on the rod journels to clean up. Losing some stroke. My goal is an offset ground crank, with 2.200 rod journals with a 4.23 stoke so my cubes will be 514. Nothing too bold. Just don't want to weld up and grind.
Current Topic - need 462 crank
Neue Seite 5
