FOMOCO Marketing Term CRUISE-O-MATIC
May 13 2008 at 10:41 PM
  (Login KULTULZ)
MEL Forum Moderator
from IP address 69.140.42.35
This is from another forum and I tought it might be interesting to some here-
http://www.fordmuscle.com/forums/c4-transmissions/474389-c4-cruise-o-matic-same.html
(Login hawkrod)
MEL Forum Moderator
207.200.116.6
I would add that there are some mistakes in that thread in regards to a Ford-O-Matic
May 14 2008, 5:38 PM
The original Ford-O-Matic was a cast iron case trans but in 59 a new option came out and it was the two speed Ford-O-Matic and it is not related to the cast iron trans which was now called a Cruise-O-Matic. The Ford-O-Matic of the 59-64 time frame had a one piece aluminum case and used a special flywheel which is very hard to find today. In the parts book this trans is refered to as an F/M/2 while the more common cast iron case trans is called a F/M or a C/M (depends on the year). Hawkrod
Hawkrod
39 Ford Deluxe Coupe
59 Tbird 430
60 Lincoln Premier
(2)62 Tbirds
(3)68 Cougar XR7-G's
69 Cougar 428CJ 4 speed
86 SVO mustang
76 F250 Crew Cab
1969 Mach I
Current Topic - FOMOCO Marketing Term CRUISE-O-MATIC
Neue Seite 5
