430 vs 462
December 20 2006 at 6:37 AM
  (Login BPerrenot)
from IP address 158.35.225.228
I am thinking about using a 462 in my 59 ranchero. However, I want to use the 58 block that I have so I can use the FE standard trans or my current FE C-6.
Questions:
1) Are the main and rod journals the same size between the 430 and the 462?
2) If I bore the 430 out to the 462 bore size, will the 462 rotating assembly fit into the 430?
If this will interchange OK, I am going to offset grind the 462 crank down to fit something smaller (maybe SBF) to get a stroke out of it. Would like to move out to about 500 CI just for the S&G's.
Anyone know the answer to the above?
(Login gary534)
70.135.218.160
Bore spacing must be same to swap crank
December 20 2006, 7:56 AM
MEL bore spacing 4.90, FE bore spacing 4.63, small block Ford 4.38, 429-460 bore spacing 4.90 ( but crank mains 3.00 vs 2.90 for MEL ).
(Login BPerrenot)
158.35.225.228
Bore Spacing
January 2 2007, 11:22 AM
and what is the bore spacing for a 462?
(Login KULTULZ)
MEL Forum Moderator
69.140.42.35
Yes
December 21 2006, 4:19 PM
The rotating asm from the 462 will fit the 430. I do not know if the 462 crank was machined for a pilot bearing, so check for that. Also be aware there was a camshaft change in 1961 and requires before and after cam and cam gears.
(Login gary534)
69.183.146.150
Misunderstood your post, Brian, sorry
December 22 2006, 8:27 AM
When you said grind 462 crank to SBF size, I missed the word " offset ". Now I understand your intention to stroke MEL. I thought you wanted to swap MEL crank into SBF. See what happens when you run out of coffee like I did. Thanks again, Brian.
(Login BPerrenot)
158.35.225.228
430 to sbf
January 2 2007, 11:24 AM
Now that would be a trick putting that big old 462 crank into a sbf.
(Login BPerrenot)
158.35.225.228
462 crank into a 430
January 2 2007, 11:29 AM
Thanks, I figure that if I use the 58 430 block which will bore .125 over no sweat, offset grind the crank by only 3/8 of an inch which is also no sweat, I will end up with about 545 Cubes. This in my 1959 Ford Ranchero with my E-475 Edsel valve covers, I'll have a real torque monster and look cool besides.
rkl307
(Login rkl307)
69.117.182.237
Re: 462 crank into a 430
March 5 2008, 3:46 PM
4.30 + 1/8" = 4.425"
462 crank 3.83" offset 3/8" = 4.205"
517", not 545"
rkl307
(Login rkl307)
69.117.182.237
March 5 2008, 3:48 PM
517", not 545"
Current Topic - 430 vs 462
Neue Seite 5
