Looking for a Harmonic Balancer
November 17 2006 at 9:20 AM
  (Login Husky35)
from IP address 66.6.80.48
I have a 59 430 and my balancer has been damaged and previously repaired. I am looking for a rebuilt balancer or a used balancer. I have seen a thread that says the FE balancer might work and that I could go to a FE fluid balacer. Anyone done this?
(Login KULTULZ)
MEL Forum Moderator
69.140.42.35
BALANCER
November 19 2006, 3:52 AM
Is the old balancer too damaged to have it rebuilt?
The crank snout sizes are the same but I have heard of no one that has attempted to use a fancy FE balancer. You would have to worry about pulley alignment and pulley bolt pattern.
(Login Husky35)
70.193.163.29
Re: BALANCER
November 19 2006, 9:49 AM
Somehow a chunk of the pulley broke off and was rewelded on. The rubber is old too. It might be fine, but why take the chance. I should be able to find a used one and have it rebuild or if the FE one works, that would be a slick option.
(Login KULTULZ)
MEL Forum Moderator
69.140.42.35
'Ya Know...
November 19 2006, 11:25 PM
If you had access to an early FE balancer, you could trial fit it to make sure everything lines up. Then order an FE HIGH-TECH balancer for that balancer application.
It would either be that or mix and match pulleys.
If you try it, please let us know what you find...
(Login BPerrenot)
158.35.225.228
430 Balancer
November 20 2006, 1:54 PM
I have two of these balancers, both used, but good as to my knowledge. Both are for the front mounted PS pump. Call mne at 281-793-1560
Current Topic - Looking for a Harmonic Balancer
Neue Seite 5
