Mercury 430 Motor Tri Power Setup
October 10 2006 at 8:45 AM
Tjerk  (Login Tjerk)
from IP address 213.51.169.199
Ebay # 150043483599,
not mine............
(Login KULTULZ)
MEL Forum Moderator
69.140.42.35
Is An EDELBROCK
October 12 2006, 5:43 AM
And has ROCHESTER 2G's mounted. This intake came in two versions;
1) Three bolt carb mounting pattern to accept HOLLEY/STROMBERG
2) Four bolt carb mounting pattern to accept ROCH
Some carb mounting pads will be hogged out to accept larger venturi bores so buyer beware.
Tjerk
(Login Tjerk)
213.51.169.199
Re: Is An EDELBROCK
October 12 2006, 1:07 PM
Have a look at a lot of E-brock intakes.
http://victorylibrary.com/mopar/edel.htm
Both Lincoln 430 intakes are mentioned, L330 and MLP6
For my light tuned FE engine the F427 intake is also mentioned.
Tjerk
Current Topic - Mercury 430 Motor Tri Power Setup
Neue Seite 5
