Howard cam for MEL
June 14 2005 at 11:35 AM
  (Login Migginsbros)
from IP address 84.191.125.238
We own a cam for our 58-60 MEL engine.The cam is marked Howard 60.
It will be a roller cam cause the lobeground is very small. The lift is more than the original 383/430 cam. Any information/data about this cam?
Thanks again.
(Login KULTULZ)
MEL Forum Moderator
69.140.54.63
Cam Specifications
June 15 2005, 12:48 AM
I am going to venture that you are going to have to hope someone that used these parts in the fifties/sixties comes across this forum and has the cam card (or specs) for the cam. If not, you will have to plot it with a degree wheel and dial indicator.
If a true roller, I would investigate using FE roller tappets and don't forget the mechanical valvetrain from the FE is mostly interchangeable with the MEL. Just take the normal precautions for valve lift, etc.
(Login KULTULZ)
MEL Forum Moderator
69.140.54.63
CAMSHAFT ANALYSIS/SPECIFICATION SERVICE
June 18 2005, 3:04 PM
http://www.ford-y-block.com/camdr.htm
I am sure that most cam manufacturers offer this service.
(Login KULTULZ)
MEL Forum Moderator
69.140.54.63
OREGON CAM GRINDING
June 19 2005, 1:40 AM
Current Topic - Howard cam for MEL
Neue Seite 5
