What is cannister above oil filter ?
August 17 2004 at 8:15 AM
Score 1.0 (1 person)
  (Login gary477)
from IP address 216.47.188.33
What is that hockey puck shaped cannister just above the oil filter on MEL engines ? Is it an oil cooler ?
(Login KULTULZ)
MEL Forum Moderator
69.140.34.250
Do You Mean...
August 17 2004, 9:35 AM
The bell shaped piece on the oil filter adaptor? That would be the oil pressure sending switch.
If not, what is your application?
(Login BYE2001)
68.126.143.186
Hockey Puck
August 17 2004, 7:18 PM
Power Steering Resevoir?
(Login gary477)
216.47.188.33
No, its much larger than a sending unit
August 25 2004, 7:53 AM
The cannister in question is not part of the oil filter adapter, its farther up, its about the size and shape of a power steering resevoir, but Ive seen it in illustrations of MEL engines that have no power steering or air conditioning ( only water pump and alternator ).
(Login KULTULZ)
MEL Forum Moderator
69.140.34.250
I Think What You Saw Is...
August 26 2004, 2:36 PM
Some installations (LINC-MERC) had a crankshaft driven P/S pump. The reservoir is smaller than the belt driven Eaton pump and is bolted to the the front engine cover tucking it in close to the engine. The photo shows the pump on the right and the reservoir on the left. I don't have an installed photo at this time. Look familiar?
(Login gary477)
216.47.188.33
Thats it alright
August 30 2004, 7:46 AM
Thanks, KULTULZ, for solving a mystery to me !
Current Topic - What is cannister above oil filter ?
Neue Seite 5
