Cooling System
November 13 2008 at 12:56 AM
from IP address 69.140.42.35
Response to Water Not flowing in my 462 mel
Have you pressure tested the complete system, including cap? Think there is any chance of a blown head gasket? Has the radiator been flow tested? There are no block thermostats, correct? Main thermostat is not put in backwards?
Do you have an old pump to check for impeller orientation? On some applications, coolant has to be routed through the heater core. It acts as a safety bypass in case the WP bypass is defective in some manner.
  1. Re: Cooling System - Theo on Dec 13, 5:56 AM
  2.
