Cam Bearings
July 24 2008 at 4:11 PM
Brian  (Login BPerrenot)
from IP address 143.111.22.22
Response to MEL 430 cam bearing question
Make sure you install the bearings in the correct sequence. IE, largest bearing in the #1 bearing position, then next smaller one, then the next smaller, etc until you have all five installed. The smallest one at the rear. Where the feed holes go DOES NOT MATTER. The groove around the bearings at the block will feed the mains.
Brian
