Rocker Arm Ratio
July 20 2008 at 2:53 AM
from IP address 69.140.42.35
Response to 58 430 cam specs
Correct, 1.76 all. In fact, the origional MEL arms had a large failure rate and were replaced by FE hydraulic arms.
What might be confusing you is the mention of a 1.5 ratio in aftermarket cam grinds. This was just the lift at which their events were taken, not actual ratio.
  1. rocker ratios - tom cassidy on Jul 20, 8:23 PM
    1. Piston Dome Shape - KULTULZ on Jul 20, 11:52 PM
