perf build
July 10 2008 at 10:07 AM
  (Login treinarts)
from IP address 140.239.87.194
Response to 430 Help
You have a heavy custom car. Your options are limited. I would not recommend spending big bucks on custom pistons, head porting, nitrous, stuff like that.
Holley makes a replacement carb that is easy to jet properly, but depending on what you have, a carb change may not be necessary. Carter carbs can be tuned for perfomance too.
The engine would need a modest cam change, have your cam reground for torque and not high RPM horse power. Take your time here, do your research on the cam profile you want. Too much cam and everything vacum will not work right. Oregon cams does this, about 150 bucks. They have done two for me.
Go to electronic ignition, several brands available.
Open up the exhaust, 2 1/2 or 3 inch pipes from manifolds back to your preference of mufflers. Flowmasters-whatever tone you like. A full length exhaust will still flow well and keep the noise behind the car. Spend some money here at a good shop.
The transmission will be a problem. 430 engine for those years have a bellhousing bolt pattern that a C-6 will not bolt up too and I do not know if a C-6, if adadpted to fit the engine will fit the chassis. From personal experiance, the stock transmission is weak and a 2000 stall convertor must be custom made. expensive. The trans can be beefed up a little, but I lost high gear several times. Just blew clutchs out. Not a trans made for high power applications. Maybe someone else knows of a solution to the weak trans. Good luck. TJR
