You can install 351 Windsor heads on a 302 for improved flow. The intake would need to be modified and port matched.
You can also run a 351 Windsor camshaft in a 302 Just remember the firing order is different.
I have done this in the past with great success.You do need small chamber heads from a 1969 motor.
As for a boss 302 head on a std 302 motor??? Not sure if that would work...
1959 Lincoln Tri-Power Coupe
1959 Lincoln Rag-Top
1959 Lincoln 4-Door (Parts)
