I just bought a roller cam home made from Brian Estrada. This is the only information I have from him about the cam: "roller cam shaft custom ground for 1.76 rocker ratio" He also sells the lifters and 'MSD electronic distributor and bronze ampco 45 gear', and has a package for 'Rocker assembly (you send in your old assembly so i can use old stands, and tension springs. But the rockers, the shafts, Wave springs and cotter pins are NEW!' I guess this might cover some of what you mentioned! Any advice on any work I would have to do after these parts would be great. Thanks a lot for your help.
