perf build
February 27 2008 at 1:52 PM
  (Login 00llama)
from IP address 69.106.78.9
Response to new- 430 rebuild
Building the enbine isn't that tough. The engine doesn't need much. Small cam, upgrade the ignition and a decent 750 CFM carb will do it. As noted, tons of stuff in this forum. Take some time and look through it. My advise would be to look at your transmission options carefully. Try to get a C-6 and 2000 stall converter behind your engine as the Mel puts out huge amounts of torque and will destroy the older automatics and flywheels. Only the 1958, 59 and 60 430s will bolt up to 390 ford transmissions. After 60, take care.
