Engine Transformations
December 23 2007 at 1:03 AM
from IP address 69.140.42.35
Response to Thanx again !
Correct. The 1958 was an animal all it's own and 59/60 saw many changes. It was completely redesigned in 1961 and went back to 4V in 1963 with many upgrades. And of course there was the 462.
Tha later cam change is gospel as it came from ISKY. They stopped making early blancs available and went to later design to eliminate cam walk and a few other problems. OREGON CAM GRINDING can regrind a later cam to the earlier specs or actually improve the whole thing.
___________________________________________________________
MEL (MERCURY-EDSEL-LINCOLN) Engine Specifications 1958/1968
383C.I. Bore 4.30” x Stroke 3.30” (1958/59) (MERC)
410C.I. Bore 4.20” x Stroke 3.70” (1958) (EDSEL)
430C.I. Bore 4.30” x Stroke 3.70” (1958/65) (LINC-MERC-TBIRD)
462C.I. Bore 4.38” x Stroke 3.83” (1966/68) (LINC)
1958 MERCURY
383C.I. 4V (Monterey Low-Torque)
312HP @ 4600 RPM CR 10.5 To 1
383C.I. 4V (Montclair Hi-Torque)
330HP @ 4600 RPM CR 10.5 To 1
430C.I. 4V
360HP @ 4600 RPM CR 10.5 To 1
430C.I 6V
400 HP (Super Marauder)
1958 EDSEL
410C.I. 4V (E-475)
345HP @ 4600 RPM CR 10.5 To 1
475 ft.lb. Torque
1958 LINCOLN
430C.I. 4V
375HP @ 4800 RPM CR 10.5 To 1
430C.I. 6V
400HP @4600 RPM
1959 MERCURY
383C.I. 2V
280HP @ 4400 RPM CR 10.0 To 1
383C.I. 4V
322HP @ 4600 RPM CR 10.0 To 1
430C.I. 4V
345HP @ 4400 RPM CR 10.0 To 1
1959 LINCOLN
430C.I. 4V
350HP @ 4400 RPM CR 10.0 To 1
1959 THUNDERBIRD
430C.I. 4V
1960 MERCURY
430C.I. 2V
310hp @ 4100 RPM CR 10.0 To 1
1960 LINCOLN
430C.I. 2V
315HP @ 4100 RPM CR 10.0 To 1
1960 THUNDERBIRD
430C.I. 4V
350HP @ 4400 RPM CR 10.2 To 1
1961 LINCOLN
430C.I. 2V
300HP @ 4100 RPM CR 10.0 To 1
1962 LINCOLN
430C.I. 2V
300HP
1963 LINCOLN
430C.I. 4V
320HP @ 4600 RPM CR 10.0 To 1
1964 LINCOLN
430C.I. 4V
320HP
1965 LINCOLN
430C.I. 4V
320HP
1966 LINCOLN
462C.I. 4V
340HP @ 4600 RPM CR 10.25 To 1
1967 LINCOLN
462C.I. 4V
340HP
1968 LINCOLN
462C.I. 4V
340HP
There may be mistakes in some of the ratings. They vary by publication. But this will give an idea of how the engine(s) progressed/degressed.
Source- Standard Catalog of FORD 1903-1998 Edited by Ron Kowalke
FORD MEL ENGINE
Ford MEL V8
Also called: Marauder V8
Manufacturer:
Ford Motor Company
Production: 1958–1967
Predecessor: Ford Y-block V8/Lincoln Y-block V8
Successor: Ford 385 V8
Class: Big-block OHV V8
Engine:
383 in³ (6.3 L)
410 in³ (6.7 L)
430 in³ (7.0 L)
462 in³ (7.6 L)
FORD developed the MEL ("Mercury-Edsel-Lincoln") engine series for use in their line of Mercury, Edsel and Lincoln models from 1958 through 1967. The MEL also replaced Lincoln's unique Y-block design. These engines were produced in Lima, Ohio at Ford's Lima Engine plant. They were replaced by the 385 series engines.
All MEL engines had wedge shaped combustion chambers formed between a flat head surface and an angle milled block deck, with the piston top determining the compression ratio and combustion chamber shape. Similar to the Chevrolet Big-Block 348 combustion chamber, also introduced in 1958, and the later 409. Unlike the Chevrolet, which had staggered valves and scalloped or M shaped valve covers, the MEL valves were inline with shaft mounted rocker arms like the FE model Ford engines which were introduced at the same time.
The MEL was similar to the Ford FE, with the same oiling system, bolt patterns, and valve stems, but was even larger. The main bearings were 2.9 in (74 mm), while the rod bearings were huge at 2.6 in (66 mm).
383
The 383 in³ (6.3 L) Marauder was the smallest member of the family. Produced from 1958 through 1960, it was only used in Mercury vehicles. It used a 4.3 in (109.2 mm) bore and 3.3 in (83.8 mm) stroke. Output began at 312 or 330 hp (233 or 246 kW), both with a four-barrel carburetor. 322 hp (240 kW) was the only output for 1959, and power dropped to 280 hp (209 kW) for the final year.
410
The least-common MEL engine was the 410 in³ (6.7 L) E-475. Bore was lower at 4.2 in (106.7 mm). 10.5.1 compression, a Holley four-barrel carb, and hydraulic lifters pushed out 475 ft.lbf (644 Nm) of torque. This engine was only used in the 1958, Edsel Corsair and Citation.
430
The 430 in³ (7.0 L) engine was produced from 1958 through 1965. It was also used in Ford Thunderbirds and was commonly referred to as the "Bulldozer" of the MEL series engines. The Super Marauder used three two-barrel carburetors. The 430 had a 4.30 in (109.2 mm) bore (same as the 383) and shared the 3.7 in (94 mm) stroke of the 410.
The compression ratio started at 10.5:1 for 365, 375, and 400 hp (272, 280, and 298 kW), but was reduced to 10.0:1 in less than a year. These 1959 engines produced 345-350 hp (257 to 261 kW), but power was down to 315 hp (235 kW) for 1960.
New pistons and a four-barrel carburetor were added for 1963. 10.1:1 compression brought output back to 345 hp (257 kW).
462
The 430 was replaced by the 462 in³ (7.6 L) engine in 1966. Bore and stroke were entirely different at 4.38 in (111.3 mm) by 3.83 in (97.3 mm) and the 462 MEL engine produced 340 hp (254 kW) and as much as 485 ft•lbf (658 N•m) of torque. This engine was fitted with hydraulic lifters and a Carter AFB four-barrel carburetor. This large torque engine was used only in Lincoln Continentals, from 1966 until mid-year in 1968 when it was replaced by the 385-series 460. Production ended after 1967. The production facilities in Lima were converted to produce the new Ford 385 engine family.
References
• Peter C Sessler (1999). Ultimate American V8 Engine Data Book. MotorBooks/MBI Publishing Company. ISBN 0-7603-0489-0.
• The Ford Mercury-Edsel-Lincoln. Retrieved on July 25, 2006.
  1. 58 430 cam bore specs - tom cassidy on Dec 27, 2:34 AM
    1. HOUSTON...We Have A Problem... - KULTULZ on Dec 28, 6:55 AM
      1. 430 cam bore specs - Tom on Dec 29, 12:03 AM
 Copyright © 1999-2009 Network54. All rights reserved.   Terms of Use   Privacy Statement
