J BIRD
May 17 2007 at 3:58 AM
from IP address 69.140.42.35
Response to 1965 430 Y Block Swap to 1959 T-Bird
The 59/60 did use the forward mounts but the FE (352) used regular positioned engine mounts. I came across a post earlier that the poster stated that he changed his 59 MEL to ride on the FE mounts and supports.
I do not see a reason this will not work. Why FORD used the forward mount on the BIRD is beyond me.
Now the only touble with a 64 430 is the unique bell pattern limiting the trans to an LX (or possibly an MX). I am not sure of the case to bell pattern on the LX as compared to the FX/MX.
Below is the front mount design as on a 1958 LINC;
This photo shows J BIRD mount;
This message has been edited by KULTULZ from IP address 69.140.42.35 on May 17, 2007 5:22 AM
This message has been edited by KULTULZ from IP address 69.140.42.35 on May 17, 2007 4:31 AM
  1. LX, MX and FX,,................ - Tjerk on May 17, 3:37 PM
    1. TRANSMISSION MODELS - KULTULZ on May 18, 3:47 AM
  2. PCA Trans Type Peculiarities - KULTULZ on May 18, 6:00 AM
  3.
