old block-late cam
February 20 2007 at 7:23 AM
  (Login 00llama)
from IP address 69.106.78.9
Response to MEL Cams/Bearings
Isky catalog says a 61-68 cam can be run in 58-60 blocks if cam bearings 1-4 from late block are put in early block and late cam gear is used. I have both cams, but have not tried bearing swap yet. Will let you know. TJR
