| mel strokerFebruary 6 2007 at 7:34 AM No score for this post | treinarts (Login 00llama) from IP address 69.106.78.9 |
Response to Where to start on a stroker. Advice needed. |
You can get 510 inches pretty easy. rod journels are 2.6 and if you offset grind crank and use 2.2 big block chevy rods it is not too tough to find right length. Trick is piston pin location. Consider using Ross pistons and having them make a fast burn combustion chamber in top of piston. A set will run about 1500.00 Good luck. TJR | |
| Responses- Fast Burn - KULTULZ on Feb 6, 10:39 AM
- fast burn tech - treinarts on Feb 7, 9:37 AM
- Thanks For Replying - KULTULZ on Feb 7, 11:59 AM
- I Found This Earlier Reply - KULTULZ on Feb 9, 6:37 AM
