MEL Strokers
February 6 2007 at 6:42 AM
  (Login BPerrenot)
from IP address 158.35.225.227
Response to Where to start on a stroker. Advice needed.
Whoaaaaaaaaaaaa, a 3/4 inch stroker? That is asking a lot from any engine, much less a MEL that has a cast crankshaft. As you know, welding a cast crank isn't a good idea. My suggestion, use a 462 crank and offset grind it about .325 or so. That will give you a **** load od cubes all by itself.
