410 FE
October 25 2006 at 2:02 AM
from IP address 69.140.42.35
Response to Help on a 410 coversion
The MERC 410 is a stroked 390 (428 crank). The pistons are unique but you say you have a set. Everything else is interchangeable. The 410/428 are balanced differently and you will need the 410/428 flexplate/damper and have it checked for proper balance while at the machine shop.
  1. All that Kultulz noted is correct except.... - hawkrod on Oct 25, 7:23 AM
  2.
