THANX HAWKROD!
August 11 2006 at 11:33 AM
from IP address 69.140.42.35
Response to Lots of back of block comparison pictures (dial up go get coffee!)
I needed that 462 shot desperately!
Excerpt From Previous Post;
HAWKROD
"The 61 is a one year only design and may be somewhere between the two or like one or the other. If anybody has a 61 block or a 62-65 block and can send me a picture or post it here it would be great as I could compare from pictures alone."
How did you come to the conclusion the 61 block is unique? I have been going on the premise (of late) that the pattern was the same from 61/65. I do not have the convenience of the 60/64 LINC-MERC MPC but the 65/72 MPC does show a service block change in 1964 (C4VY 6010-A). Does your MPC show additional part nos. from 1961 to 1963?
Are you going to put an early MX behind the 430 in your BIRD?
  1. My Bird has the stock engine and trans.... - hawkrod on Aug 11, 4:30 PM
    1. Thank you very much, hawkrod - gary534 on Aug 15, 8:59 AM
    2. 61 - 63 block - Brian on Aug 15, 1:18 PM
      1. The 61 block is different from a 62 and newer somehow... - hawkrod on Aug 15, 6:09 PM
        1. 61 to 65 blocks - Brian on Aug 16, 12:33 PM
          1. Actually that is only sort of true - hawkrod on Aug 16, 2:56 PM
            1. MEL Blocks - Brian on Aug 17, 7:12 AM
        2. 1961/1962/1964 Bell Comparisons - KULTULZ on Aug 24, 10:03 AM
          1. The C4VY block replaced the C2VY and are interchangeable - hawkrod on Aug 24, 3:01 PM
