Some Sources
November 24 2005 at 4:57 AM
from IP address 69.140.243.168
Response to HELP NEED ROCKER ARM SHAFT
A rebuilder;
http://www.rockerarms.com/ford.htm
You supply your own core for the rebuild. This might help or not. Sounds like you need service replacement parts. The FE shaft can be substituted but the stands are unique.
Maybe someone will come on with used pieces. I will keep searching for a possible source.
  1. used - buddc on Nov 24, 6:54 PM
    1. 430 rocker arm shaft - mike on Nov 24, 8:16 PM
    2. Rocker arm shaft - mike on Nov 24, 8:17 PM
    3. I am looking for timing cover assembly from a 430 - hawkrod on Nov 26, 8:50 AM
      1. Re: I am looking for timing cover assembly from a 430 - J-Bird on Dec 7, 9:27 PM
      2. Thermostat Housing Photos - Anonymous on Dec 7, 10:18 PM
