| It's a 383October 21 2005 at 6:34 AM No score for this post | Anonymous (Login J-Bird430) from IP address 66.81.210.36 |
Response to Engine I.D. Hard To Make |
I measured the stroke at 3.3 and that makes it a 383 just like you figured with the red valve covers.
My interchange manual says the intake, carb, exhaust manifolds, rods, cam, heads, timing gear-chain are the same as my 430 but it lists different pistons and block. How can this be if both sport a 4.3 bore?
The crank fits ONLY the 383 but can I install a 430 crank and get a 430.... that's something I need to research.
Thanks,
Dave
aka
J-Bird430 | |
| Responses- 383/430 Block - KULTULZ on Oct 22, 12:15 AM
- 383/430 Block - J-Bird430 (Dave) on Oct 22, 9:14 AM
- I Need To Get Up Off My Lazy Posterior... - KULTULZ on Oct 22, 5:20 PM
