Common Occurrence
June 4 2005 at 1:16 AM
Score 4.0 (1 person)
from IP address 69.140.54.63
Response to Distributor Help!!
Where the distributor base rides in the bore designed to hold it, the O-RING on the distribuor housing becomes hardened to the point of actually freezing in the bore.
When you come across one frozen this badly (and it is common on other engine series also), you try to soak the area immediately at the valley pan where the distributor housing protrudes. LIQUID WRENCH...PB BLASTER. It may have to soak for several days before being able to break loose (use oil filter wrench gingerly around distributor bowl to try and break loose)(may only get a few degrees of rotation at first-re-soak).
Some may be frozen to the point where breakage is the only alternative. Coat the O-RING (sparingly) with anti-seize when setting the new one in.
You can find a replacement salvage, E-BAY or rebuilt.
  1. Ahhhh - Hobbz on Jun 4, 9:47 AM
    1. Road Draft System - KULTULZ on Jun 4, 11:24 AM
      1. Ok... what about manifolds? - Hobbz on Jun 5, 2:26 PM
        1. What Model Car Is The 430 In? - KULTULZ on Jun 5, 5:02 PM
          1. 64 Continental - Hobbz on Jun 6, 4:56 PM
            1. The Trouble With 61/ CONTINENTALS - KULTULZ on Jun 6, 10:16 PM
              1. Hmmm - Hobbz on Jun 7, 10:39 AM
                1. Keep Us Posted! - KULTULZ on Jun 7, 8:40 PM
                2. Hey Hobbz - PYRO777 on Nov 6, 6:23 PM
