Freeing Up Engine
May 17 2005 at 1:12 PM
from IP address 69.140.54.63
Response to kultulz
Yes, let the solvent sit in the cylinders for a few days and then try to turn manually. Can you get a socket on the crank snout bolt? It would be much easier than trying to turn it with the ring gear. Try it turn a little-forward and backwards. Go easy on it. If she breaks free, put fresh oil and filter into, and with spark plugs out spin with starter motor to clear cylinders. If you have an oil pressure gauge, this would be a good time to see what pressure she pumps. Install plugs and fresh fuel and try to start her. Keep the RPM's low until you are sure of engine condition.
Don't forget, the backwards engine will have a reverse rotation cam, so don't get them mixed up if you have to tear them down.
Let us know...
Did the other poster leave an E-MAIL address?
  1. Backwards? - Mike Henry on May 30, 9:50 AM
    1. Automotive- Distributor At Front Of Engine n/m - KULTULZ on May 30, 3:33 PM
      1. Thanks - Mike Henry on May 31, 12:36 PM
        1. "Could you recommend a shop east of the Mississippi River?" - KULTULZ on Jun 1, 12:24 AM
          1. That's a great idea. - Mike Henry on Jun 1, 5:27 AM
            1. HEY LISTEN! - KULTULZ on Jun 1, 10:16 AM
