I have always used FEL-PRO gaskets. Most any quality gasket will suffice. Are you going to do the front seal also? Does the EDSEL use the crank driven or belt driven power steering pump.
Do you need an on-line source for FEL-PRO?
I am not sure where an intermediate shaft can be found. Can you measure the one you took out and compare it with the length given on the previous post?
