DIsc Brakes
June 23 2004 at 6:03 PM
from IP address 69.140.63.191
Response to Disc Brakes conversion
The easiest way to convert an earlier LINC (in my opinion) is to find a later LINC 65/69 that uses KELSEY-HAYES four piston caliper brakes. Take the spindles, brake parts, rotors and the proper dual master cylinder/valving for the system. This system caliper is a non-sliding four piston design that has a tendency for piston freeze-up. The typical solution is stainless sleeves/pistons.
It is also possible to use the spindle from a mid-seventies intermediate to convert to single piston sliding caliper brakes. This will require some modification(s) in brake tube routing and valving.
http://www.hotrodders.com/t34753.html
I have also seen advertised on e-bay a GM changeover kit that bolts onto your existing spindle.
  1. Spindle Geometry..... - Theo on Jun 24, 1:26 AM
    1. Geometry - KULTULZ on Jun 24, 4:01 AM
      1. sorry Kultulz, on this one i will have to disagree vehemently.... - hawkrod on Jun 24, 6:49 PM
        1. Consider This... - KULTULZ on Jun 25, 6:16 AM
          1. i can only tell you what i know..... - hawkrod on Jun 25, 7:01 PM
            1. You Are Correct... - KULTULZ on Jun 25, 10:54 PM
