Transmission Useage Concern
March 25 2004 at 5:05 PM
from IP address 69.140.62.242
Response to 430 in a 58 ford.. whats needed?
Been thinking... (that's scary)
You said use origional trans. When we did this swap years ago (430 into '57), we used a big block (FE) toploader. Everything went together. I am not quite sure the earlier Y-BLOCK trans will have the same mounting flange pattern, same input shaft length, pilot bearing ID and so-on.
The Y-BLOCK trans may also not hold up to the torque of a 430. If everything matches, use the Y-BLOCK 3/S but you might want to consider finding a later 3.03 3/S (1963 up) for strength and synchronized first gear.
Don't want you cussing me on final assembly...
  1. my concern also - chris on Mar 27, 5:27 AM
    1. Flywheel... - KULTULZ on Mar 27, 12:19 PM
      1. flyweel fixed - chris on Mar 27, 2:40 PM
        1. WHEW (Sigh Of Relief) - KULTULZ on Mar 27, 4:23 PM
          1. Re: WHEW (Sigh Of Relief) - chris on Mar 27, 4:40 PM
            1. I Understand Completely... - KULTULZ on Mar 27, 7:06 PM
              1. Swap mounts. - Charlie S. on Apr 11, 11:40 AM
                1. Wondering... - KULTULZ on Apr 14, 9:30 PM
