Top Control Switch
May 9 2006 at 7:19 AM
  (Login wgh234)
from IP address 24.250.242.33
Response to 67 fairlane 500 convertible for parts
I need the top control switch  #15668, if it is still available. Email $ value, wgh234@gmail.com
The dash trim treatment that goe across the front of the dash around the headlight switch, ignition switch. Mine is broken around the steering column, if you can coax yours off without damage I'd buy it as I haven't seen any place to buy a replacement.
If the car has a clock, what color is the wire feeding the clock?
Thanks.
This message has been edited by wgh234 from IP address 24.250.242.33 on May 9, 2006 7:25 AM
This message has been edited by wgh234 from IP address 24.250.242.33 on May 9, 2006 7:21 AM
