on what journal diameter did you run 0.0015 on the con rod bearings?2.100"or 2.310 ? and at what rpm ?what style of rotor was it. and what gear lenth was the exturnal pump? what size pick up do you use -8 , -10 or - 12 pick up? what is the belt ratio? what end do you feed the oil in, at the back or front?
