Mr. Gasket PN# 214
December 23 2008 at 4:06 PM
Andy  (Login C_andy460)
from IP address 24.40.186.237
Response to Re: Intake gaskets...
I like the Mr. Gasket intake gasket part number 214. I use spray copper coat sealer and coat both sides. Most any type silicon will work for end seals just use a good fat 1/4 inch bead so it will seal. Torque the 5/16 bolts to 20#-25# and the 3/8 bolts to 28#-32#'s. Start with the 3/8 bolts next to the middle and work to the ends. Torque the 5/16 bolts in the middle last. Do one bolt on one side then one bolt on the other side. Some of the middle bolts holes are open on the bottom. Put some sealer on the bolt threads of these.
Andy
